6 Pages «<3456>
JOHN-GT40 BUILD DIARY Options
JOHN-GT40
#81 Posted : 07 July 2021 13:27:04
CHASSIS PLATE DECAL ARTWORK & DECALS DONE BY FAST SIGNS ENFIELD
MORE UPDATES WILL BE SOON
THANKS
JOHN RICHARD POULTER
JOHN-GT40
#82 Posted : 08 July 2021 12:37:48
coolant tank over flow pipe fitted and installed
more updates will be posted soon
thanks
JOHN-GT40
#83 Posted : 10 July 2021 20:14:38
rear wheel spinner
that does not fit
using a fine file remove all chrome around the entry off wheel spinner
when the chrome is removed it has a black plastic colour underneath
you can test fit at this stage and you will see it fits perfectly
many thanks to the forum members roy, mark & carl for highlighting this problem
more posts and updates will be posted soon
thanks
#84 Posted : 11 July 2021 06:55:28
That was Roy that caught the problem, and posted about it. Roy, Mark and Carl are the Go-To car guys.
Albert Eisenstein
JOHN-GT40
#85 Posted : 16 July 2021 19:22:15
Issue 16 & 17 have arrived
My only instruction is assemble without rear wheels fitted
Be very careful when assembling the suspension unit and suspension spring
Things I had to do
Rear wheel spinner for the other side needed filing to make it fit correctly
Rear engine mounts needed filing at entry point to cross member beam
This was temporary installed and secured in place with FP02 screws at fronts points on engine cross member beam and on the rear engine mounts
Only painting and filling was
Rear caliper pistons done in titan gold
Cross member beam mounting screw hole filled with humbrol model filler
Sanded smooth
Painted in flat aluminum
Now weighs in at 3.841kg
More updates will be posted soon
Thanks
semaj
#86 Posted : 18 July 2021 23:38:35
Nice work john. I seem to be an issue behind now, only just had pack 16 delivered.
Building:
Ghostbusters Ecto-1, Ford GT40, Battleship Bismarck, gone in 60 seconds Eleanor mustang
Complete:
R2D2, Red Bull RB7 RC, Shelby GT500 'super snake'
JOHN-GT40
#87 Posted : 22 July 2021 14:01:45
1:8 scale rear axle cv rubber boots have turned up from alli express
Fit absolutely perfect
Thanks
JOHN-GT40
#88 Posted : 23 July 2021 11:21:24
Up to issue 17
All looking good and great
More updates and posts will be posted soon
Thanks
mr_frog
#89 Posted : 23 July 2021 12:48:02
Rear Wheel Spinner problem....
'That was Roy that caught the problem, and posted about it. Roy, Mark and Carl are the Go-To car guys'.
S'cuse me???
Did I not post this on the 'Discussions' page on 4th July?
Your's feeling unappreciated. Cheers Admin!
mr_frog
#90 Posted : 23 July 2021 12:56:33
S'cuse me???
mr_frog
It indeed was Mr Frog who raised this issue with the rear spinner.
All I did was acknowledge it and pass the info to senior admin for DeAg to look at...
JOHN-GT40
#91 Posted : 23 July 2021 16:30:54
To Mr Frog,
I sincerely apologise as I did not see your advanced posting of the rear wheel spinner issue
I sincerely appreciate yourself highlighting this problem
As good communication throughout the forum
Makes the assembly process a lot more easier
Once again thanks for highlighting this problem
As soon as next lot of pdf & issues become available
Thanks
#92 Posted : 23 July 2021 21:15:18
S'cuse me???
mr_frog
Hi,
I’d no idea! My apologies.
M
Albert Eisenstein
mr_frog
#93 Posted : 24 July 2021 10:39:41
no worries folks.
it's easy done.
Mr-frog
JOHN-GT40
#94 Posted : 26 July 2021 12:08:09
New decals ordered to go on top of doors
They are
Jacky Ickx signature
Jackie Oliver signature
Image shows how it will look
Thanks
JOHN-GT40
#95 Posted : 29 July 2021 14:36:33
Signed signature decals of
Jacky oliver
And
Jackie ickx
Have been applied to tops of doors
More updates and posts will be posted soon, as soon as new pdf and parts become available
Thanks
JOHN-GT40
#96 Posted : 13 September 2021 17:03:26
ISSUE 18 TURNED UP
engine crank case and sump cover are very rough casting and require lots of filing and filling with model filler
2 x crankcase screw holes filled
lower bottom half painted in flat aluminum
top of crank case painted in flat blue
fan belt painted in flat black
all pulley fronts done in chrome metallic pen
oil cap painted in flat black
chrome metallic pen used on the valve cover circles
overall standard quality of these parts in issue 18 i thought personally did not meet the required high standard but still gets sent out to subscribers
lots of additional work that is unnecessary
rjfk2002
#97 Posted : 16 September 2021 18:25:00
John - what material is the engine block and pipe made of? All metal or is the pipe plastic?
JOHN-GT40
#98 Posted : 21 September 2021 19:19:01
Block and sump are bad castings of alloy metal
Pipework and pulley set is done plastic
Rear brake line tubes are in black plastic tubing
The block and sump are seriously rough and in my honest opinion
Is a major case off get parts out with no quality control measures implemented
Subscribers suffer due to unnecessary work due to bad quality workmanship
These required a lot of filing and model filler and sanding to bring to a standard that is acceptable
Then painting
Front of pulleys using metallic chrome pen
Water pump pulley housing painted blue
Silicone Hose joint painted blue
Pulley belt painted Matt black
Lower half of crank case painted flat aluminum
Upper half of crank case painted flat blue
Valve cover circles done using chrome metallic pen
Oil filler cap painted in flat black
Hope this helps everyone
New order placed with RB Motion for:-
2 x 1:8 scale spark plugs
2 x 1:8 scale black angled spark plug boots
2 x 1:8 scale black straight spark plug boots
1 x 1:8 scale black straight distributor cap boots
2 x 1:8 scale valve stems
New order with eBay
5 mtrs of 1mm CSA orange insulated single cable to be used as spark plug leads
1 x pack of 2.5mm orange cable ties
1 x roll of 5mtr long orange 3mm wide pin stripe tape
more updates will be posted soon when new pdf and parts become available
Thanks
John-GT40
Alfordboy17
#99 Posted : 24 September 2021 13:05:15
Although this is my first posting I have been following with interest many different forums over the years but I am intrigued to know how you received a pack when the system is in lockdown.
John
JOHN-GT40
#100 Posted : 24 September 2021 22:08:23
i always pay for my subscription via paypal direct to deagostini model space
issue available is posted out
never ever had any issues with deagostini model space uk
roy and ian at model space uk are always available for factual information when next pdf go live online and what new parts have arrived in warehouse
thanks
JOHN-GT40
Guest (5)
6 Pages «<3456>
This page was generated in 0.484 seconds.
