5 Pages «<345
JOHN-GT40 BUILD DIARY Options
JOHN-GT40
#81 Posted : 07 July 2021 13:27:04
CHASSIS PLATE DECAL ARTWORK & DECALS DONE BY FAST SIGNS ENFIELD
MORE UPDATES WILL BE SOON
THANKS
JOHN RICHARD POULTER
JOHN-GT40
#82 Posted : 08 July 2021 12:37:48
coolant tank over flow pipe fitted and installed
more updates will be posted soon
thanks
JOHN-GT40
#83 Posted : 10 July 2021 20:14:38
rear wheel spinner
that does not fit
using a fine file remove all chrome around the entry off wheel spinner
when the chrome is removed it has a black plastic colour underneath
you can test fit at this stage and you will see it fits perfectly
many thanks to the forum members roy, mark & carl for highlighting this problem
more posts and updates will be posted soon
thanks
#84 Posted : 11 July 2021 06:55:28
That was Roy that caught the problem, and posted about it. Roy, Mark and Carl are the Go-To car guys.
Albert Eisenstein
JOHN-GT40
#85 Posted : 16 July 2021 19:22:15
Issue 16 & 17 have arrived
My only instruction is assemble without rear wheels fitted
Be very careful when assembling the suspension unit and suspension spring
Things I had to do
Rear wheel spinner for the other side needed filing to make it fit correctly
Rear engine mounts needed filing at entry point to cross member beam
This was temporary installed and secured in place with FP02 screws at fronts points on engine cross member beam and on the rear engine mounts
Only painting and filling was
Rear caliper pistons done in titan gold
Cross member beam mounting screw hole filled with humbrol model filler
Sanded smooth
Painted in flat aluminum
Now weighs in at 3.841kg
More updates will be posted soon
Thanks
semaj
#86 Posted : 18 July 2021 23:38:35
Nice work john. I seem to be an issue behind now, only just had pack 16 delivered.
Building:
Ghostbusters Ecto-1, Ford GT40, Battleship Bismarck, gone in 60 seconds Eleanor mustang
Complete:
R2D2, Red Bull RB7 RC, Shelby GT500 'super snake'
JOHN-GT40
#87 Posted : 22 July 2021 14:01:45
1:8 scale rear axle cv rubber boots have turned up from alli express
Fit absolutely perfect
Thanks
JOHN-GT40
#88 Posted : 23 July 2021 11:21:24
Up to issue 17
All looking good and great
More updates and posts will be posted soon
Thanks
mr_frog
#89 Posted : 23 July 2021 12:48:02
Rear Wheel Spinner problem....
'That was Roy that caught the problem, and posted about it. Roy, Mark and Carl are the Go-To car guys'.
S'cuse me???
Did I not post this on the 'Discussions' page on 4th July?
Your's feeling unappreciated. Cheers Admin!
mr_frog
#90 Posted : 23 July 2021 12:56:33
S'cuse me???
mr_frog
It indeed was Mr Frog who raised this issue with the rear spinner.
All I did was acknowledge it and pass the info to senior admin for DeAg to look at...
JOHN-GT40
#91 Posted : 23 July 2021 16:30:54
To Mr Frog,
I sincerely apologise as I did not see your advanced posting of the rear wheel spinner issue
I sincerely appreciate yourself highlighting this problem
As good communication throughout the forum
Makes the assembly process a lot more easier
Once again thanks for highlighting this problem
As soon as next lot of pdf & issues become available
Thanks
#92 Posted : 23 July 2021 21:15:18
S'cuse me???
mr_frog
Hi,
I’d no idea! My apologies.
M
Albert Eisenstein
mr_frog
#93 Posted : 24 July 2021 10:39:41
no worries folks.
it's easy done.
Mr-frog
JOHN-GT40
#94 Posted : 26 July 2021 12:08:09
New decals ordered to go on top of doors
They are
Jacky Ickx signature
Jackie Oliver signature
Image shows how it will look
Thanks
JOHN-GT40
#95 Posted : 29 July 2021 14:36:33
Signed signature decals of
Jacky oliver
And
Jackie ickx
Have been applied to tops of doors
Thanks
Guest (4)
5 Pages «<345
This page was generated in 0.240 seconds.
