2 Pages <12
3D Printed Highly Detailed Aftermarket Upgrades Options
TonyRR
#21 Posted : 11 March 2021 20:04:53
Another great part that you can improve is the ramp hidraulic lifters. I've redesigned them to make this part screen accurate as much as possible.
You can get a set in this link to my shop!!
308 Bits Shapeways shop DeAgo Falcon Ramp Lifter Set
TonyRR
www.shapeways.com/shops/308Bits
Higly detailed 3D printed upgrades for scifi kits
TonyRR
#22 Posted : 15 March 2021 20:19:14
The DeAgo hold is also a zone to be heavily upgraded. I've designed some pillars, screen accurate at the max.
You can see the attached shot.
You can buy it here
308 Bits Shapeways shop Deago Hall Pillars
TonyRR
TonyRR
#23 Posted : 19 March 2021 20:50:46
I've modelled a lot of upgrades for the DeAgo Falcon during these years.
In this render you can see some of the hold upgrades available in my 308 Bits Shapeways shop.
Enjoy!!
You can buy all of them in my 308 Bits Shapeways shop.
308 Bits Shapeways shop DeAgo upgrades
MILLENNIUM FALCON DEAGO HALL UPGRADES SHOWROOM.png (1,034kb) downloaded 13 time(s).
TonyRR
#24 Posted : 19 March 2021 22:35:13
Drool Drool Drool Thes are just amazing upgrades! If i ever get the remaining issues im going to be spending some serious coinage here Love
Gray
TonyRR
#25 Posted : 19 March 2021 22:53:16
Gray
Many thanks!!! If you have any questions please let me know.
TonyRR
TonyRR
#26 Posted : 26 March 2021 17:25:28
What about a new and accurate turret gun well? I've designed a very screen accurate turet gun well with all the details and with the right seat. And it has pre drilled holes for 0.25 mm fiber optics.
And it can be installed with no hassles on the stock hull, because it has the stock part dimensions. For ease of paint it's sliced in two halves.
You can get it in my 308 Bits Shapeways shop, of course, in this link:
308 Bits Shapeways shop DeAgo Turret Well Stock
TonyRR
TonyRR
#27 Posted : 06 April 2021 19:32:49
A set of 3D printed hold pits grille it's a great addition to the DeAgo Falcon.
I've modelled a set totally screen accurate, that's available in one piece or in three separated halves.
Of course it's fully compatible with my hold grille.
You can get it at my 308 Bits Shapeways shop on the link below.
308 Bits Shapeways shop DeAgo Falcon Hall Pits Grille
TonyRR
TonyRR
#28 Posted : 11 April 2021 17:44:24
I recommend to upgrade the DeAgo Hall Nav console. The stock one is innacurated and doesn't have the right size.
My Hall Nav Console has more than 80 pre drilled holes for 0.25 mm fiber optics too, so it's a win win.
You can get it here!
308 Bits Shapeways shop DeAgo Hall Nav Console
TonyRR
TonyRR
#29 Posted : 12 April 2021 19:41:25
What about a set of external warning lights? This is a missing feature on the DeAgo!!!
I've designed a set of external DeAgo housing warning lights, that you can light with small led.
You can get them in my shop, as usual.
308 Bits Shapeways shop DeAgo External Lights
TonyRR
TonyRR
#30 Posted : 18 April 2021 20:34:55
The stock engine vents can be upgraded with a fan under the grilles.
I've designed a set of fans to be installed under my engine vents grilles.
You can get them in my 308 Bits Shapeways shop!!
308 Bits Shapeways shop DeAgo Engine Vents Fans
TonyRR
TonyRR
#31 Posted : 26 April 2021 19:14:40
For the very advanced modellers I've designed a full set of screen accurate ramp walls. The problem is that they don't work with the stock electric motor and ramp elevation system. But you can adapt them.
You can get the ramp panels and the hull ramp interlock in my 308 Bits Shapeways shop.
308 Bits Shapeways shop Millennium Falcon Deago Ramp Panels
TonyRR
TonyRR
#32 Posted : 02 May 2021 20:25:03
The engines of the DeAgo Falcon also can be improved heavily. One detail are the engine louver arms, that on the stock DeAgo aren't very well designed. My upgrade for this part is totally screen acurate, and fits perfectly in place. And my plates overhang a bit, like on the studio model.
You can get them in my 308 Bits Shapeways shop under the Falcon DeAgo tab.
308 Bits Shapeways shop DeAgo Falcon Engine Louver Arms with Plates.
TonyRR
TonyRR
#33 Posted : 20 May 2021 01:46:26
On the cockpit there's a little detail that's missing, the overhead controls.
I've designed this part to be attached on the stock cone, with some sanding and putty. Also, it fits perfectly my upperwall and cone upgrades.
You can get it here:
308 Bits Shapeways shop YT1300 DeAgo Cabin Cone Upper Controls
TonyRR
TonyRR
#34 Posted : 06 June 2021 19:44:48
The engine vents grilles also can be upgraded with my designs. On the model the vents are blind, so I've designed a set of engine vents with real see through grilles!!
You can get them in my shop.
308 Bits Shapeways shop DeAgo Engine Vents Grilles
TonyRR
#35 Posted : 07 June 2021 06:36:33
Jees Tony, you are making me wish I was building another Falcon! You’ve come out with so much more in the last 5 years, I could get it pretty darn close to truly screen accurate....
I also see you are having fun with your SLA printer. And I just remembered about the X-wing parts! My apologies! Do you still want them?
Albert Eisenstein
TonyRR
#36 Posted : 12 June 2021 17:15:52
Hey Mark!!
Many thanks for your kind words!! Yeah!! Lots of fun with my printers!! It's really amazing for me what can I create!!
Yep!! Send the X-Wing parts please. I'm waiting for them!!
And keep me posted about the Star Destroyer. If you can reach any parts to send to me, go ahead please!!
Cheers mate!!
TonyRR
TonyRR
#37 Posted : 11 July 2021 13:48:20
You can upgrade the ramp entrance with my interlock part. It's totally screen accurate with the 32" DeAgo Falcon and it's a must have part.
The stock part is very simple and unnacurate.
You can get it in my 308 Bits Shapeways store.
Shapeways 308 Bits shop YT1300 DeAgo Falcon Ramp Interlock
TonyRR
TonyRR
#38 Posted : 13 July 2021 18:53:48
If you have all the 100 issues but you have missed the issue 100A, don't worry, I've got you covered!! I've designed a set of missing parts, missing greebles on the DeAgo Falcon, the 100A issue greebles. I've designed them totally screen accurate, far better than the stock parts!!!
If you need them just go to my 308 Bits Shapeways shop.
308 Bits Shapeways shop YT1300 DeAgo Missing Parts 100A
TonyRR
TonyRR
#39 Posted : 02 August 2021 00:18:26
For those that want to have the quad dish on the DeAgo Falcon, I've designed too a complete replacement composed by the mount and quad dish. Of course is totally screen accurate at the max.
308 Bits Shapeways shop YT1300 DeAgo Quad Radar With Mount
TonyRR
TonyRR
#40 Posted : 05 September 2021 17:59:00
The turret well window is a part that you can upgrade too. I've designed a totally accurate window that fits perfectly the stock turret well.
You can get it in my 308 Bits Shapeways shop.
308 Bits Shapeways shop YT1300 DeAgo Turret Well Window
TonyRR
2 Pages <12
This page was generated in 0.220 seconds.
