Joined: 30/01/2013 Posts: 4,608 Points: 13,907 Location: Monmouthshire UK
Here we go with model 2 of my dio - the famous 25 pounder Field Gun. A couple of interesting facts about this one, a well trained crew of 6 could fire off 8 rounds per minute and the total time from towing position to being unhitched and stabilised to firing the 1st shell was just 45 seconds! Im finding the etch very tricky on this kit and have botched a few bits up, i also have too much CA on some of the parts but hoping it will not show when primed. Whenever I feel like giving up on the etch I take a look at Jase's Bismark then I see how easy I have it Ok, some pics of the work so far - stevie_o attached the following image(s):
Hi Steve looking good note your comment on the CA. you don't have to use CA unless there is some stress on the part. if its not load bearing try using PVA or even a spot of varnish, both are easier to clean up if you get some seepage. J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Looking good steve Etch mmmmmmm try the 1/700 scale stuff now that's a nightmare Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Pro  Groups: Registered
Joined: 17/03/2010 Posts: 301 Points: 941 Location: fife
looking good steve, i have the same kit so interesting to see how it develops current builds
victory,endeavour,thermoplye,constitution
Hi Steve, you are doing a super fine job  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
A bit more done on this today, completed the gun and got the primer and base coat on. I wanted the black to show through the sand base coat as these guns were mostly repainted dark green european theater and were quick painted in the sand colour. There is still the ammo limber to build yet plus the crew of 6. Next for the gun is a coat or 2 of pledge or klear as it was once known, i use this as it gives a great surface for washes plus it also gives a very nice satin look to the paint which looks more like painted metal than plastic. Wheel hubs to do also stevie_o attached the following image(s):
Looking great  looking forward to seeing how you finish with washes. J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 17/03/2013 Posts: 193 Points: 534 Location: United Kingdom
Hi Stevie_o Looking good  . Can't wait to see it completed. Taz “Count your age by friends, not years. Count your life by smiles, not tears.”
Joined: 04/04/2010 Posts: 3,964 Points: 11,809 Location: uk
Nice subject, well done. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
 Nice work on the gun Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Practically finished, there is a sand weight pack to be added but as this is going to be part of a dio im going to add that later. The ammo limber build and crew coming shortly. The wash and weathering was done with vallejo game colour washes and also used a cheap "desert" eye makeup kit for pigment - both shown below - stevie_o attached the following image(s):
These were on my camera as well, may as well put them on stevie_o attached the following image(s):
Some nice weathering looks great J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Rank: Master       Groups: Registered
Joined: 05/09/2012 Posts: 1,402 Points: 4,690 Location: Beaminster, Dorset
Great job Steve, looks very realistic. Looking forward to seeing the Diorama.
The next part of this kit is the ammo limber, I made a deliberate point of not weathering the gun and limber as one item as they would have suffered varying levels of wear and usage. Apart from the gun crew this completes Pt 2 of the dio. The gun crew consists of 6 figures but I dont want to build these yet as I need to see where I want them on the dio first, I may even have them doing other duties No diary for this build but a couple of pics of the painting stages - First, paint only but no detailing  Next, with a Vallejo Black wash thinned down a fair bit.  Then 2 pics after a Sepia wash thinned down   And then with some metallic detailing and a few filter washes of sand. I will be making some final layer additions later when I have the exact colour of the desert scene etc but until then this will do.     There were also shells and cases with this kit but these will be done when the dio is coming together. Next up is pt 3 - the Stuart M3 "Honey" Tank with interior  Steve
nice work Steve
Jase“Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Thankyou Jase Here's the gang so far, stevie_o attached the following image(s):
