A Bit of thought on Planking ! Options
RussG
#1 Posted : 01 April 2010 02:41:23
Hi Fellow Builders LOL
I am currently following a build on Model Ship World and thought this might be interesting to us all Taken from site as follows -
"A little more progress, and my first major deviation from the kit itself. I stated when I began that I would be sticking to the kit as much as possible, but after I finished planking the hull I found that just wasn't feasible. The kit is single planked, and the sapelly provided is nice enough, but a combination of a slightly less than expected finish, and some trouble in the planking led me to the inescapable conclusion that leaving it single planked just wasn't going to do. I was not particularly pleased with the results of my first efforts. A part of this (a smaller part truth be told) I blame on the wood, and a much larger part I blame on my own planking skills. I have already mentioned I believe that the size of the hull on this ship was unlike anything I had ever encountered before, and each strake was planked with two pieces. This led to a lot of gaps, and some fairly uneven runs. In the end, even after sanding, the color difference in the wood, and the general look just wasn't appealing.
This led me to a pretty lengthy internal debate of whether to paint or leave the wood. That's been going on since I started it. I want to leave it as a wood finish, since I like the look better, but the color scheme of the Victory is so well known and recognizeable. If I was to paint it, then the planking job wouldn't matter as seriously, since it would be filled and then painted. But in the end I decided to keep it as wood.
Luckily, we have one of the greatest carpentry stores I have ever seen here, a place called Lee Valley. They have bundles of cherry veneer for a pretty unbelieveable price. I had grabbed a few of them some time back with the intention of saving them for some kitbashing in the future, and I figured no time like the present, so I started on a secondary planking layer of the lower hull. I have one side done so far, and while not completely perfect, the effect is far and away better than the original, and I'm more than satisfied.
I still have to give the second planking a final sanding and coating, but even so, I'm still pleased with the look after the second planking is on.
The cherry veneer is a bit light in color, but a coat of water based vermont maple stain, along with the natural color of the cherry has darkened it nicely. It won't be as dark as the original sapelly, which was a bit closer to a walnut look, but I prefer the lighter surface. Once it's got a coat of wood oil I will have a final evaluation and make my decision. So far though, it's looking good to stay as a wood finish."
Links to the build is here Static HMS Victory (Artesania Latina)
A Comment from Admin would be nice to see if they have changed the original to Double Plank ???
Waiting for Pt 2 & 3 !!!!
Russ
Happy Building, Russ
On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build Diary
Under the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
ArtfulBodger
#2 Posted : 06 April 2010 16:12:54
Russ G
Sadly I'm inclined to agree. The Bounty was double planked and gave a very pleasing result but single planking is far too flexible. Also checked out your quotes... OMG has the price of glass risen!
ArtfulBodger
Previous Build:
HMS. Bounty
jonny7england
#3 Posted : 06 April 2010 17:17:00
I had just viewed you build and I can see exactly what you were talking about..I have double planked almost all my models except for RMS Titanic, well technically single planked but there had to be an extra thin layer fitted to the hull to give it that ribbed look..I suppose the jury is still out on whether you could have called it double planked..still, your model looked pretty damn good. What I thought was most annoying was when you got strakes that that had to be curved and pointed to fit those final gaps in the hull only to have it come up short, or the gap was a seemingly impossible shape to fill with a strake. I think that's when a second language usually French come to the fore..hope you enjoy the new build. John.W
captainalan
#4 Posted : 07 April 2010 03:23:05
After long and careful consideration, Ive decided to double plank my victory, what I'm going to do is wait till Ive all the bulkheads and keel parts, then I'm going to sand them down 1/2 mm.so the overall dimensions will remain the same but at the same time the gun ports will have added depth. i have this feeling that a single planked hull of this size will just not be strong enough.
not only that but if you get a feel for the 1st planking the 2rd layer in theory should go on better and without any hiccups.
jonny5j
#5 Posted : 07 April 2010 08:16:17
Rank: Semi-Pro Level 2
Hi lads i must admit after following this build i too am tempted to double plank the hull
john
HMS VICTORY
HMS SURPRISE
ASTON DB5
MCLAREN MP4-23
#6 Posted : 07 April 2010 12:47:31
Hi,
We are working with our supplier looking at planking options, and there may well be some element of double planking. As soon as we know the exact detail we will advise you all.
thanks
Admin
hudsonrobert49
#7 Posted : 07 April 2010 13:02:25
Build-Diary Medal: Build-Diary Medal of HonourOutstanding Build: An award for an outstanding build
Hi well I hope I will be getting double planking for my HMS Surprise, re your statement,
FOR THE Surprise
Kit features:
* Traditional double planking on frame wooden hull .
* Factory precut keel and all main frame parts
* Highest quality planking mahogany, walnut and lime woods
* High quality fittings in white metal burnished or in real die-cast brass.
* Sails set full sewn. You just have to rig them at the masts.
Rob
Bridlington.
Built Flying Scotsman (Train). Collecting HMS VICTORY
RussG
#8 Posted : 07 April 2010 18:12:35
admin wrote:
Hi,
thanks
Admin
Many Thanks Admin
ginian
#9 Posted : 06 May 2010 00:00:52
Many thanks admin, really pleased you are responding to all the feedback.
This page was generated in 0.171 seconds.
