Tip’s for better model Photography Options
TRGRichie
#1 Posted : 22 March 2018 14:06:46
Red Medal: Red MedalTurquoise Medal: Turquoise Medal for model making know-how contributionBuild-Diary Medal: Build-Diary Medal of Honour
Basic Model Photography Tips.
Considering how much time we spend building our models it is always nice to be able to take good pictures of them during the build and of the finished model, therefore it is always disappointing if these pictures don’t do all your hard work justice! So what follows is some super easy tips to achieve excellent results armed in many cases with nothing more then a smart phone and some white card! I’ve broken these easy tips into 4 basic parts as follows:
Part 1 - The Back Drop
Part 2 - Basic Lighting
Part 3 - Framing & Angles
Part 4 - Post Production
AUTO FRUMP STOMPER
Custom Porsche RS Build - http://forum.model-space...aspx?g=posts&t=25728
TRGRichie
#2 Posted : 22 March 2018 14:07:34
Part 1, The back drop - Infinity Curve Or Sweep
The clean, professional look of an infinite white set is ideal for model photography as it isolates the model and removes distractions and gives the impression that the background extends to infinity. Basically it isolates your model and adds clarity to the photograph
The ‘infinity curve’ (or sweep) is a simple photographic technique to achieve. You can use almost any type of material to create your own DIY infinity curve – a large sheet of white paper/card or ironed white sheets for example, as long as its white and is flexible enough to bend it will more then likely do the job. Obviously the size of material used, will depend on the size of the model you wish to photograph.
Here is an example of the ‘infinity curve’ achieved with a simple sheet of white paper – note the sweep.
TRGRichie attached the following image(s):
AUTO FRUMP STOMPER
TRGRichie
#3 Posted : 22 March 2018 14:08:37
And this second shot we can see the results achieved from this very simple set up using my iphone. (unedited – as shot straight from phone).
AUTO FRUMP STOMPER
#4 Posted : 22 March 2018 22:33:02
Useful tips being provided there Rich and look forward to seeing what other tips will be revealed along the way. Think many members will find this topic really useful in helping them show their work in its best light....Cool Cool
TRGRichie
#5 Posted : 09 April 2018 19:13:57
Part 2 – Lighting.
Obviously there are lots of lighting options and techniques and many of these will involve extra equipment and in many cases extra space – the techniques and tips within this thread are to illustrate how to take a good picture with extra cost and just a smart phone.
A room with a window is perfect as long as it casts good light on the subject.
The bigger the window, obviously the more light you’ll get in.
The light and the shadows created from the window will all depend on how close or indeed for far away from it you are – you may not have the option to play with this distance but if you do its worth experimenting to see the difference it makes.
Your other option for lighting is artificial, in most cases probably just the main room light – again this can be more than adequate in most cases – and again where you chose to place your subject in relation to this light source is what will count.
AUTO FRUMP STOMPER
TRGRichie
#6 Posted : 09 April 2018 19:14:21
A simple window is always a great light source.
AUTO FRUMP STOMPER
TRGRichie
#7 Posted : 09 April 2018 19:15:09
A window and the room light combined provide in most cases adequate light.
AUTO FRUMP STOMPER
TRGRichie
#8 Posted : 09 April 2018 19:16:01
This picture was taken with just the widow as the light source – notice how the shadows fall, and the side of the subject facing the viewer is in shadow!
AUTO FRUMP STOMPER
TRGRichie
#9 Posted : 09 April 2018 19:16:46
The same shot but this time with the main room light added – this has lit the area that was in shadow.
AUTO FRUMP STOMPER
TRGRichie
#10 Posted : 09 April 2018 19:17:44
We could however have just turned the subject so the light fell on the side closest to the viewer if we didn’t want to add another light source.
AUTO FRUMP STOMPER
TRGRichie
#11 Posted : 09 April 2018 19:18:56
And once again the same shot with the main room light on – again you can see how it has brightened the areas that were in shadow.
AUTO FRUMP STOMPER
TRGRichie
#12 Posted : 09 April 2018 19:20:55
All the above images were taken on my iphone and are as shot (unedited).
Hopefully this illustrates how with just the light sources you have available it is still possible to be creative with your model photography by just paying attention to where the light and the shadows fall.
Hope this makes some sense - please ask any questions as I'm more than happy to help.
And stay tuned for Part 3 - Angles & Framing (coming soon)
Thanks
Rich.
AUTO FRUMP STOMPER
#13 Posted : 09 April 2018 23:04:41
Personaly think your missing one. A good camera with a close up function
-Mark Twain
#14 Posted : 09 April 2018 23:16:17
You can have the best camera in the world but knowing how to properly use it is another matter.
#15 Posted : 09 April 2018 23:41:34
Interesting information here. Just goes to show you don't have to go to any expense buying lighting equipment to produce decent results..... As for camera's, most mobile phones have camera's that will do just nicely for producing pics of models....Cool Cool
#16 Posted : 10 April 2018 00:18:07
I personally think the last picture is more than adequate, especially if it was taken with something like an IPhone 7 or equivalent. Should you have something from the latest LG range then you have a camera that has more functions and facilities than a lot of average digital cameras.
Top flight cameras cost more than another big kit in the stash, so I know where my vote lies.
Keep up the good work Richie.
Cool Cool Cool Cool Cool
#17 Posted : 10 April 2018 00:59:46
BigGrin The advice given so far is great for smaller models but when you need to take pictures of larger models such as the range of ships currently on offer you still need to plan the correct lighting to obtain the best result.
Just my opinion of course but I think lighting and planning of any subject to be photographed to show the detail required can be a minefield. Its another case of trying to be a master of many things and the need to have the correct lighting for the subject can make or break that picture.Cool
#18 Posted : 10 April 2018 06:37:45
Lots of good advice here. Recently I accidently realised that a blue backdrop acctually shows off a model better than a white one, in my opinion
-Mark Twain
#19 Posted : 10 April 2018 06:49:47
It depends on what the overall colour of the subject is. Such as a blue backdrop for the blue Rossi bike won’t highlight as good as a white backdrop, and a white model on a white background has the same effect.
TRGRichie
#20 Posted : 10 April 2018 07:29:35
Yes agree to a certain degree, but no matter what size the principles are the same.
I would like to point out that I am purposely trying to give tip on how to get a good picture which kit you will already have, so no expense.
If you guys want a tutorial on professional photography then there are plenty out there on the web, or if you ever in Yorkshire your more then welcome to visit my studio for a lesson.
Many thanks
Rich.
AUTO FRUMP STOMPER
