12 Pages 123>»
Lancia Delta Martini WRC 1991 + Lancia Delta Test car 1991 Hachette 1/8 Options
frah2o
#1 Posted : 08 November 2018 11:30:39
Hi, I want to share with you my lastest project 1/8.
I started it in May 2018, so I have to post a lot of work in progress. I hope you’ll enjoy to watch it.
I post in the next day several pics, so if I not response quickly…I’ll made it later.
So let’s start
After having checked and cut some choices in the models that I'm doing (Mustang and Yamaha M1 off) I stopped to make local mind on my projects.
The Golf project is almost on par, except that in order to go forward now I am forced to wait all the elements of the bodywork to do tests, paint stripping and then repaint: that is, I think in the early 2019
I have several collections (all in 1/8) active during the accumulation phase:
- 80% Delta
- Countach LP500 at 60%
- Ferrari 312 T4 at 57%
- Porsche RS 2.7 at 30%
I started on Delta project for 2 reasons: 1) it is the most advanced model of accumulation and 2) I want a "historical" subject.
At the beginning I wanted to start with the 312, but the covered wheels and the WRC win.
There will be a lot of work to do taking cares of various factors: my small skills and the poor detail proposed on this model edited by Hachette.
In the next almost immediate post, I begin to post something about what I started doing.
As a premise I can say that for this scale there is nothing transkit or improvement . Just only 2 kits produced by 2 guys known on the FB group dedicated to the construction of this model.
Courtesy of Hachette Italia
frah2o
#2 Posted : 08 November 2018 11:44:59
Looking around and looking at the various photos I started to put my hands on the bigger and workable pieces.
The lower floor seems like a BBurago, not that I will have much chance to make it more realistic, but at least I try to give it some small
I started by mounting the rear fenders and I plastered them. In the meantime I saved a picture showing the floor from below and the various welds of the panels; if truthful I would add the weld lines and then obviously repaint everything.
For the internal floor, apart from starting it and repaint it, I want to try the first exercise with a plasticard to see if there are any ribs that are missing or that have been omitted.
It will be and hard work onthis rally icon.
frah2o
#3 Posted : 08 November 2018 11:50:04
I started from the exhaust line and before filling it I glued all the pieces using the CA in the coupling pins and the other glue in the joint points.
Same work of gluing, filling and sanding on differential box, transmission shaft, joint cover and fire extinguisher
frah2o
#4 Posted : 08 November 2018 11:57:43
Started on the engine, a lot of mistakes here:
- 3 exhaust holes
- intercooler completely wrong
Courtesy of Cheral Auto restoration
frah2o
#5 Posted : 08 November 2018 11:59:12
Rollcage and inner floor with some details to add
frah2o
#6 Posted : 08 November 2018 12:08:09
Proceding with floor with milliput and extra weld lines
frah2o
#7 Posted : 08 November 2018 12:10:58
Drilling the 4 exhaust hole, add the 4th manifold (first version), add extra details on head
frah2o
#8 Posted : 08 November 2018 12:13:07
4th manifold using a piece of sprue, add the oil livel stick, add some lubrificants line on turbo (to finished)
frah2o
#9 Posted : 08 November 2018 12:36:04
Work on inlet manifold, on engine block, new coolant hose. Work on timing belt carter and alternator bracket
L’alternatore è stato riprosto a sogliola, dovró inventarmi qualcosa per creare il pezzo mancante che sta dietro al monoblocco
Poi iniziamo con l’arcano della tubazione che a rigor di logica mi sembra dell’impianto di raffreddamento. Parte dalla zona pompa acqua, sale e termina senza un perchè nella parte alta laterale dietro al coperchio punterie.
courtesy of ewrc.com
Coutesy of dnaracing.com
frah2o
#10 Posted : 08 November 2018 12:38:25
Another some work on intercooler unit. In the future i'll add mesh on radiator an new inferior duct from intercooler and turbo.
Dopo aver puntato le 2 paratie latarali ho diviso l’intercooler dal convogliatore, ho ricosrutito il fondo. Ho tagliato l’occhiello del piolo sul convogliatore per poi inserire l’intercooler rifatto.
frah2o
#11 Posted : 08 November 2018 12:40:02
Some new lubrification pipe and some mod on oil stick
frah2o
#12 Posted : 08 November 2018 12:52:21
Other work on coolant pipe on the rear side of engine block, some work on alternator
frah2o
#13 Posted : 08 November 2018 12:54:25
Some future details to improve for electronic ignition, and start the work on air box that need a new intake (not present on hachette) filter box
Courtesy of Ewrc.com
Courtesy of Autotecnica.it
frah2o
#14 Posted : 08 November 2018 12:56:32
COntinuing with coolant hose with selfmade pipe on radiator. Some work to fornt mount oil radiator
Tratto da video Assitenza ufficiale Lancia
frah2o
#15 Posted : 08 November 2018 12:58:17
Self builf of the other side coolant pipe on engine and radiator
kpnuts
#16 Posted : 08 November 2018 12:58:23
Great progress.
frah2o
#17 Posted : 08 November 2018 12:59:20
For today it's all. I'll continuing to post soon
Bye and I hope enjoy you.
sandro71
#18 Posted : 08 November 2018 13:33:50
Hi,
I saw your perfect work on this Project. Are you located in Italy?? Because I/we have Problems to get such models from Italy to the rest of Europe e.g. Germany.
could you please give us an idea or a hint, where we can order such Projects to get them delivered outside of Italy.
In France for e.g. there is an Independent webside. Do you have something similar in Italy??
Sandro
#19 Posted : 08 November 2018 20:02:33
This is coming along nicelyBigGrin liking the additional weld details.
#20 Posted : 08 November 2018 20:56:25
BigGrin Interesting kit, and can't wait to see what you do with her ThumpUp
Guest (4)
12 Pages 123>»
This page was generated in 0.237 seconds.
