Problems Fitting the Body Options
Rod Schneider
#1 Posted : 05 December 2018 16:09:12
I've been struggling trying to get the body mounted on the chassis. The huge number of wires in this model seem to be making it very difficult to get everything to fit. I've tried about 6 times so far, but the bundle of wires that run under the right door sill seem to be getting in the way. There aren't any good photos in the assembly guide for routing the wiring and the paper tabs supplied with the kit don't adhere very well.... Has anyone else had this problem, and how did you solve it? Right now, I'm nearly to the point of just removing most of the wiring..................
#2 Posted : 05 December 2018 16:23:01
The wiring is a one of them jobs you need to take your time on. Have you looked at the pictures in the official build. They should help. The only other way is to use clear tape in a few more places to hold wires out if the way.
https://forum.model-spac...amp;m=292930#post292930
Chris.
On the Bench
#3 Posted : 05 December 2018 16:32:41
Also, have a look at the final section in my custom build.
I spent a little while getting the wiring out of the way. It can be done so don't give up...
https://forum.model-spac...spx?g=posts&t=29664
Rod Schneider
#4 Posted : 05 December 2018 16:34:48
Thanks! roymattblack, those pictures look very helpful. I'll tackle it again later today. Thanks again.
Karamike
#5 Posted : 06 December 2018 15:14:21
Hi. Just completed my build and I had a terrible time fitting the body. Firstly the horn wire is very short and you have to get very close to fit it. I struggled but got friend to help ...he shone torch as I lowered the chassis on and he poked the wires in place. It was a very tight fit but finally fitted..but not the best design I am afraid. To make matters worse one of the reat tail lights now not working but there is no way I will ever repeat fitting this body. The build guide looks so easy and I wonder did he ever connect the wires as we never see lights working. Good luck.
#6 Posted : 06 December 2018 15:36:16
Sorry to hear of the problem you had.
As for the lights working, if you look at the official build final pictures you will see the lights on.
https://forum.model-spac...amp;m=293059#post293059
Also the final gallery pictures show them.
https://forum.model-spac...amp;m=293190#post293190
On the Bench
#7 Posted : 06 December 2018 15:38:33
Sorry to hear you had a few problems.
Once I had taped my wires into place and out of the way, the body went on fairly easily.
The dashboard was a bit tight in the door apertures but that was about it.
I've attached a few dodgy images of my car with the lights on.
They are blurry as I didn't use flash, and left the room fairly dark - hence a slow hand held exposure...
Karamike
#8 Posted : 06 December 2018 16:43:07
Hi, i used the pdf guide to make sure using correct screws. Lights did work before fitting body, i must have trapped one. Been trying to figure out how to break into good wire on working light but all hidden under the chassis. Pity because all others working.
Rod Schneider
#9 Posted : 06 December 2018 20:55:57
Thanks for the very helpful replies, especially roymattblack. The pictures were a big help! I got the body installed, finished up the model, and everything works! Thanks again!!
#10 Posted : 06 December 2018 21:54:09
I'm really happy if any of my waffle-build was of use.
TRGRichie
#11 Posted : 07 December 2018 17:14:21
Build-Diary Medal: Build-Diary Medal of HonourRed Medal: Red MedalTurquoise Medal: Turquoise Medal for model making know-how contribution
keep on waffling buddy!
I'm an issue away from fitting the body but I have already been wire tidying ready for this stage.
Rich
AUTO FRUMP STOMPER
Custom Porsche RS Build - http://forum.model-space...aspx?g=posts&t=25728
zuff
#12 Posted : 15 January 2019 13:28:41
Seems like this is a common problem. Our friends in France had similar problems but one forum member solved it by cutting side extensions off floor pan. See last page on this:
http://forum-auto.caradi...uits/sujet17288-4725.htm
#13 Posted : 15 January 2019 13:41:33
One or two members did seem to have a problem with fitting it but I didn't have a problem with mine in any way.
On the Bench
This page was generated in 0.122 seconds.
