9 Pages 123>»
Ant62 victory build Options
Ant62
#1 Posted : 05 January 2019 17:17:37
Im wondering if its easier to build the entire false keel before i add the ribs!!!!
Reason im asking if i build the false keel then i can attach it to a jig and from there.....
Building.
Corel Albatross 1840......
#2 Posted : 05 January 2019 18:25:32
Hi Ant
My recommendation would be to build as per the instructions, the official build and the official video build. Once you have glued the frames to the keel then you can set the whole assembly into the build jig. Official Build and video build follow the instructions very closely and highlight potential problems you may come across during the build.
Link for the Official Build
https://forum.model-spac...topics&f=17&p=2
Link for the Video Build
https://www.youtube.com/...pjUDnPzoDagw3u2T7tQIBv4
Ant62
#3 Posted : 08 January 2019 15:15:21
Well i finally got started today and gave it 2 1/2 hrs dont time fly....
Any way ive done the ribs etc.
A light sand over the joints and ive stuck them together with gorilla wood glue i had left over from a few mths ago.....
I will try n add pics later..
Building.
#4 Posted : 08 January 2019 17:55:27
Hi Ant
Glad to see you're up and running BigGrin
Your right, the time does fly when having fun ThumpUp
A word of caution though - be careful with the Gorilla Glue! I used it on my Trinny build. Had a problem, which needed to be dismantalled, and the glue set like concrete. I would advise Aliphatic Glue. Same grab, but any problems you can at least get it to come apart with hot water!
Here is a link that you may find interesting:
https://www.model-space.....1540462758.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=112847303
Gray
Ant62
#5 Posted : 09 January 2019 13:57:11
Downloaded an app for my note 8 to resize so lets see...
Below is what i managed to do i two n half hours on the false keel and the ribs..
Non of the ribs are fixed at all......
Building.
Ant62
#6 Posted : 09 January 2019 14:04:31
Decided to start the launch today as for the next few days im a tad busy so ive freed up time to concentrate upon the launch..
Building.
#7 Posted : 09 January 2019 14:07:32
Great start Ant look forward to seeing your progress.Cool BigGrin
Ant62
#8 Posted : 09 January 2019 15:09:45
Had a bit of time spare so i glued in the launch ribs....
Building.
#9 Posted : 09 January 2019 19:31:32
Great to see your pics Ant and it looks like you're off to a very nice start, all neat and tidy. On the launch, be very careful when it come to fairing and the frames, they are very delicate and easily broken.... Cool Cool .. Look forward to seeing your next update....
#10 Posted : 09 January 2019 22:11:12
Great start, looks like you've got right into it.Cool
#11 Posted : 09 January 2019 22:56:34
BigGrin Well done Ant ThumpUp , looks like your really getting the hang of this, and enjoying your build to boot Love
Keep it up
Gray
Ant62
#12 Posted : 10 January 2019 10:43:44
Only problem so far is the one the part 3 supports on the launch..
The one on the photo is extremely loose...
So i need to somehow keep it in place...
I have had two thoughts.
One is to try and put a slither into the joint where it attaches or just a tiny spot of superglue on the outer edge to hold it...
Or
I could sand the edge of piece 3 and slot it back in after to plank it..
Any other ideas that may help....
Building.
#13 Posted : 10 January 2019 11:15:50
Or
Hi Ant,
The two #3 formers are temporary formers to aid with the planking of the hull. You can glue the formers to the build jig but not to the frame. You can apply a little glue to the small tab at the base of #3 that fits into the frame. This should be enough to hold the formers in place. Also, when planking ensure you do not glue any planks to these #3 formers. You can sand the edges of the formers as part of the fairing process then glue them to the jig when done, just take care you don't take off too much material when doing so, check often... When you come to separate the launch from the jig these two formers should simply fall away from the assembly.
Hope this helps.
Ant62
#14 Posted : 10 January 2019 11:35:34
Cheers for that...
I will glue them to the jig later..
There is no mention of this in the instructions......
Building.
#15 Posted : 10 January 2019 11:40:08
Ant62 wrote:
Cheers for that...
It shows this in steps 6 & 7 of the instructions and it is mentioned in the Official Build Diary for Stage 6. The official build follows the instructions very closely and gives additional pointers and tips to assist you....
https://forum.model-spac....aspx?g=posts&t=729
Ant62
#16 Posted : 10 January 2019 20:51:09
I had a spare hrs to kill this morning so i started on the launch planking..
Mmmmmm..
Never done anything remotely close to planking before so this is my first attempt...
1hr ended up turning into 3hrs overall....
I have some priming and filling to do i think i did ok....
Building.
Martyn Ingram
#17 Posted : 10 January 2019 20:53:44
BigGrin Very nicely done Ant looking forward to seeing your your next update
Martyn
Building ?
Next Build ?
Ant62
#18 Posted : 11 January 2019 14:10:20
Primed..
Filled.
Primed.
Filled.
Base coat..
launch pic 7.jpeg (61kb) downloaded 41 time(s).
Building.
Ant62
#19 Posted : 12 January 2019 09:47:18
I got into the painting of the launch exterior yesterday..
I had some acrylic paints from the plane i built with my nephew spare so though why not..
Noticed i kept the boat on the jig for easier handling when painting..
Still requires a few coates though..
Building.
#20 Posted : 12 January 2019 11:24:02
Looks like you're making good progress Ant, look forward to seeing more....Cool Cool
Have just sent you a PM...
9 Pages 123>»
This page was generated in 1.828 seconds.
