How to not get a cloudy Satin Finish Options
#1 Posted : 24 March 2019 22:51:23
I tried to apply Satin Varnish again today with bad results AGAIN!!.
I used Vallejo Satin varnish shaken for 3 minutes mixed with UMP thinner also tried with water. Sprayed at 15 Psi. Got a White finish. Was not impressed on my Tornado.
So I read to spray over with Klear again to get rid of the Milky look. Luckily it worked.
So back to square one I had a Brain wave . I mixed the Satin With Klear (to act as a carrier) at 1:3 highest being the Klear. I gave it a try and it worked. No cloud and a great Satin finish. I also used a hair dryer to dry the varnish instead of blowing the airbrush over it.
Maybe others can help or put up their ways to spray Matt and Satin.
On the Bench
This page was generated in 0.121 seconds.
