Help Needed to Unglue Akagi Ribs that have already been Glued. Options
dbartonjr
#1 Posted : 20 May 2019 13:27:16
Suggestions for fixing a very stupid mistake. I made a mistake when I glued rib 20 and 21 in the wrong order with Gorilla Glue. Unfortunately it has cured so steam will not work. I am hoping that I do not have to purchase the first 3 shipments again. All suggestions appreciated. Oh yes this is for the Akagi build.
Current Builds: Yamato
On the Bench: Akagi, USS Missouri
#2 Posted : 20 May 2019 16:22:39
Hi Blink
I have just googled "Gorilla" glue and it seems that its not going to come apart easily, if at all. Unless somebody else knows otherwise?
What you have not told us is, how far you are into the build. (A photo will help)
Depending on where you are with the build, I have a theory that you may be able to make paper templates of the offending ribs and then make new ribs with the relevant size plywood and having cut away the incorrect ribs replace them in the correct position.
This is of course dependant on where you are in the build as previously mentioned and your skill level, as some very accurate work will be required.
When you get round this issue the one tip you need is to use PVA wood glue in the future as this can be steamed apart in case of an error.
Derek
#3 Posted : 20 May 2019 16:27:21
As Derek had already said fairly bomb proof this stuff seems to be.
There are some tips here that involve acetone and superglue remover but no guaratees just how well tjis would work.
Best i can find to be honest.
https://www.google.co.uk...en-gb&client=safari
#4 Posted : 20 May 2019 21:21:47
acetone works , but you may need several applications to soften it up.
dbartonjr
#5 Posted : 23 May 2019 11:37:13
Thanks to everyone's suggestions. I have had a good look at the boat and since no sides have been added I think a bit of sanding will work as well. I dry fitted the deck and everything seems to fit so I may go with that solution unless someone can identify a flaw in this strategy. I will try acetone before I go with this solution. Thanks to everyone for their suggestions.
Dan
This page was generated in 0.093 seconds.
