what is the connecting piece on the led wiring called? Options
x_dfo
#1 Posted : 22 October 2019 03:03:04
Is the female plug on the end of the LED engine light strip called a JST connector? 2.54mm 2pin?
Thanks!
#2 Posted : 22 October 2019 07:59:07
It is a JST connector, Japan Solderless Terminal, and the female is on the end of the LED that will slot into the male. As for the size there are various sizes for the JST connectors. Can’t remember what size they were but using a ruler might help you.
#3 Posted : 22 October 2019 14:49:54
here is a website with a chart to help you identify exactly which size jst connector you have. I use them all the time for electronics projects and you can buy mating pairs on amazon and ebay
https://core-electronics...is-a-jst-connector.html
x_dfo
#4 Posted : 22 October 2019 16:19:52
Thanks all, this is what I needed.
