4 Pages 123>»
MV Port Adelaide Options
John Passmore
#1 Posted : 25 November 2020 04:47:19
Publisher Medal: Featured Build of the MonthRed Medal: Red MedalOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of Honour
Hi Everyone
I have decided to start another project - a scratch build of MV Port Adelaide...BigGrin
Here is some information....Cool
Can anyone advise me why I can only get 2 or 3 minutes typing time before everything disappears?...Confused
JohnP
John Passmore attached the following image(s):
John Passmore
#2 Posted : 25 November 2020 05:17:56
Hi Everyone again
The drawing is scaled 1:160 so things are going to be pretty small....Cool
Most fittings such as windlass, cargo winches, davits, cranes, derricks and samson posts will have to be made...Cool
I have started building, using 3mm MDF for the Keel and Hull Frames. I will also use 2mm "bendy" ply and 1mm balsa for plating...Cool
More pics to follow.
JohnP
budgie
#3 Posted : 26 November 2020 08:27:28
BigGrin Hi John
Cool Will be following with interest,really looking forward to seeing her come together
Apparently she was 473 feet long so i imagine your hull will be just under a meter long which is a good size to work on
A lot of the fittings at that scale can be small and fiddly so I will be watching and learning
Cheers Stew
#4 Posted : 26 November 2020 08:47:31
BigGrin Definitely sounds like your going to have your hands full with this one!
But certainly an interesting project ThumpUp
Regards Gray
#5 Posted : 26 November 2020 20:40:39
John
That looks a very interesting project you are starting.
Really looking forward to your updates and seeing how it all progresses as this type of build is new to me.
Hope it all goes well.
John Passmore
#6 Posted : 01 December 2020 03:25:34
budgie wrote:
BigGrin Hi John
Cheers Stew
Hi Stew
Thanks for looking in....yes, the model will be 93.5cm lth o/all x 12cm beam +/-....Cool
There's a lot of nutting out to do...BigGrin
JohnP
John Passmore
#7 Posted : 01 December 2020 03:30:50
Regards Gray
Hi Gray
Thanks for your insight - yeah, I've done a lot of thinking and wondering (how I'm gonna do it)...Blink But I've made a start on the keel. Pics following shortly.
JohnP
John Passmore
#8 Posted : 01 December 2020 03:35:50
birdaj2 wrote:
John
Hi Tony
Thanks for the kind words of encouragement, and yes the build is very new to me as well...Blink But I love ships of this period with all the cranes, derricks and winches everywhere - and with a bit of superstructure thrown in as well...Laugh
JohnP
John Passmore
#9 Posted : 01 December 2020 03:40:15
Hi Everone
I have the keel marked and cut out, using 3mm MDF which is quite easy to work with - so long as you're careful...Cool
I'm trying the old slotted method as used on SotS and hope it works out...Blink
JohnP
budgie
#10 Posted : 01 December 2020 19:09:06
BigGrin Hi John
looks like you are off to a good start
Will be interested in how you make the frames from the body plan
Confused I get confused depending on who's diary you read...Confused the body plan gives the maximum width of the hull so some say you have to reduce the frames to compensate for the thickness of the material used to "plank" the hull
Some don't bother therefore I dither a lotLOL
Lookin' forward to your next update
#11 Posted : 01 December 2020 23:47:41
John
Good to see you making a start.
I am also interested to see how those plans get turned into frames.
Wish you well with it.
John Passmore
#12 Posted : 03 December 2020 04:50:15
budgie wrote:
BigGrin Hi John
Hi Stew
It doesn't really matter how it's done as the difference will be only +2mm max each side...Cool I am forming precisely to the drawing and will be using 2mm bamboo for the planking.( lots left over from the Sovereign)...BigGrin
JohnP
John Passmore
#13 Posted : 03 December 2020 04:57:01
birdaj2 wrote:
John
Hi Tony
I made paper templates ( 2 for each profile ) then after taping together to form the total rib frame, I transposed to the MDF before cutting the rough shape with a coping saw...BigGrin Then I fine shaped initially with metal files - round and half round coarse cut and sanding....This proved very tiring so I splashed out on a Dremel...BigGrin
JohnP
#14 Posted : 04 December 2020 00:14:16
You've certainly taken on a challenge with this one John and I'm sure you'll do a superb job with her. Looks as if you're off to a great start and I will definitely be following with a great deal of interest.....Cool Cool .. Good luck with the build....
John Passmore
#15 Posted : 05 December 2020 07:32:16
Hi Alan
Yes, you're right it all certainly needs a lot of forethought, I have cut all the rib frames but forgot to include in my previous post...Blushing BigGrin
Thanks for the nice words of encouragement, much appreciated...Cool
JohnP
John Passmore
#16 Posted : 05 December 2020 07:37:30
Hi Everyone
I forgot the pics of the frames in my last post...Blushing
The first 6 (bow frames) are going to need a lot of tickly fine tuning as they don't quite match the deck plans - some are too wide and some too narrow but all cut precisely to the frame plans...Blink
JohnP
budgie
#17 Posted : 05 December 2020 20:49:08
Hi John
Drool looks nice and cleanDrool
Noticed you have strips going across the frames is that for supporting the deck
Also noticed you have cut out middle of frames are you thinking of r/c or is it just to keep the weight down and assist with planking
#18 Posted : 06 December 2020 22:33:33
Am seeing some really nice methodical work being done John, she's coming along very nicely.... Have a feeling I'm going to enjoy this build....Cool Cool Cool
John Passmore
#19 Posted : 07 December 2020 03:12:14
budgie wrote:
Hi John
Hi Stew
The strips serve 2 purposes, strengthening and forming of the deck plates which are concave from the centreline to scupper each side to allow water draining...Cool Pics below...
What's r/c? The cutouts were made by cutting smaller frames from the inside the bigger ones...BigGrin
Rrgards
JohnP
John Passmore
#20 Posted : 07 December 2020 03:19:43
Gandale wrote:
Am see some really nice methodical work being done John, she's coming along very nicely.... Have a feeling I'm going to enjoy this build....Cool Cool Cool
Hi Alan
Thanks for the very nice comments.
Yes, there is a lot of trial and error going on...BigGrin I only have the one simple A0 size line drawing and the 2 photos to work from - plus a lot of detail stored in my memories of my seafareing days...BigGrin
JohnP
4 Pages 123>»
This page was generated in 0.267 seconds.
